Post your Computer
RE: Post your Computer
Postby shovenose » July 2nd, 2011, 4:56 pm
Of course you need it.
Re: Post your Computer
Postby c_hegge » February 17th, 2012, 10:01 pm
Talk about thread revival, but I decided to add a few pix of my main PC's internals
Postby shovenose » February 18th, 2012, 8:39 am
Nice PC :D
That ugly PSU looks out of place tho...
I think you should have kept the Antec and eBayed the gray thing :)
Postby c_hegge » February 18th, 2012, 6:16 pm
Nah. The Delta is better built than the HCG-750, and quieter.
Postby c_hegge » February 23rd, 2012, 6:43 pm
I just got a new enermax Vegas for my PC. I replaced the bottom front fan after it started getting noisy.
Postby shovenose » February 23rd, 2012, 7:01 pm
That looks a bit off now...
maybe replace all the fans with the same one?
Postby c_hegge » February 23rd, 2012, 10:40 pm
Yup. Another one is starting to rattle now. It will be the next to go. To bad they're $35 each. I mean, $105 is a lot to spend on a few fans.
Postby shovenose » February 24th, 2012, 10:46 pm
Ouch, yes it is. Won't Antec replace the fans for you?
Postby c_hegge » February 25th, 2012, 5:25 pm
Nah, it's out of warranty now. Besides, even if they did, they wouldn't send me enermax fans.
I think I'll just replace one each time I can part with $35. At least it doesn't feel as bad as spending $100 in one go.
Postby shovenose » February 26th, 2012, 1:54 pm
True :)
Funny thing is, I've never had any of the fans fail in the few (shitty) cases I've bought new. And they've always been quiet, too!
