Thermaltake 750W
Re: Thermaltake 750W
Postby Galib » March 12th, 2012, 6:52 pm
Firstly give the AC power to PSU with Power cord . Then measure the voltage of Green Cable at ATX connector (Which is shown in c_hegge's first Picture ) with a Multimeter . Is +5V Present in Green Cable??
Then measure the voltage of Purple Cable not Blue Cable . Is +5V present in Purple cable ??
And can we see the picture inside of your PSU ?
Galib
Postby Nuke » March 13th, 2012, 2:23 pm
I've got no camera to take a picture with. Sorry. And...
How can I put the 24-pin connector into the motherboard if there's a paperclip blocking the way? o.0
EDIT: Pulled the paperclip out and now the motherboard has a green light but the DVD drive isn't opening so I can't install my operating system.
Nuke
Postby c_hegge » March 13th, 2012, 5:26 pm
You don't insert the ATX connector into the board with the paperclip in. If you just insert the paper clip into the ATX connector - without the motherboard connected, the PSU should turn on. If not, then you have a problem.
Postby Nuke » March 13th, 2012, 7:39 pm
Well, I tried to open the DVD drive with the motherboard disconnected and the paperclip in, and it worked.
But yeah, how do I get this to work? I mean, isn't power to the motherboard necessary? o.0
Nuke
Postby shovenose » March 13th, 2012, 7:41 pm
Hmm, sorry about the confusion.
What we're trying to do is confirm that the PSU is functional. We're taking the motherboard out of the equation by shorting the power-on connector...
Postby Nuke » March 13th, 2012, 7:43 pm
Ahh. So how do I get this computer (intended as a web server) to work?
Nuke
Postby shovenose » March 13th, 2012, 7:46 pm
Well, the PSU should be functional then, at least somewhat, if the disc drive works.
What are the full specs? CPU, RAM, motherboard, etc.
Thanks!
Postby shovenose » March 13th, 2012, 7:53 pm
Hmm... when was that motherboard puchased?
c_hegge calls it "ASDS - Asus Sudden Death Syndrome" sometimes they just die (lousy manufacting)
Postby Nuke » March 13th, 2012, 7:54 pm
Oh wow.
Well, I don't think it's dead, because it had the green light on earlier.
But nothing worked when it had that green light on.
December.
Nuke
Users browsing this forum: No registered users and 74 guests
