Apparently my CPU pins are bent.
Discuss CPUs (Processors) here.
Postby Nuke » March 25th, 2012, 10:26 am
Pretty sure I can't use the CPU.
Anyone think I can use it?
(AMD Bulldozer)
Nuke
Re: Apparently my CPU pins are bent.
Postby c_hegge » March 25th, 2012, 1:15 pm
How badly are they bent? is it possible to straighten them? I've straightened pins with a stanley knife blade several times before. I also have a Socket AM2 CPU which has two or three pins missing but still works. It all depends on which pins are in question.
Postby Nuke » March 25th, 2012, 1:29 pm
Oh. There are too many really badly bent ones, I think.
I'd show a picture, but I have no camera.
Anyway, I'll...just...try bending them back. I'll tell you how that goes.
Nuke
Postby Klinc » April 9th, 2012, 10:59 am
if its bent you can still use it if you can straighten it a bit. How did you bend it btw?
3DMARK11
Klinc
Postby shovenose » April 9th, 2012, 11:44 am
Supposedly razorblades work wonders for straightening those suckers :)
Postby Nuke » April 10th, 2012, 4:40 pm
They're bent. Probably because that liquid cooling I tried installing before had some false advertising on it.
But yeah I failed. So now I'm just buying a new CPU.
Nuke
Postby Nuke » April 11th, 2012, 7:22 pm
Oh yeah, by the way, the cooler was Antec.
Nuke
Return to CPU
