Can't get my computer to work...again.
Re: Can't get my computer to work...again.
Postby c_hegge » April 17th, 2012, 3:20 am
So, maybe the PSU has been causing the problems with both boards. Hopefully, it didn't fry them both.
Postby Nuke » April 24th, 2012, 5:16 pm
I'm just going to buy a VPS instead of use a dedicated server now, and cut down on all of the things that I was going to do. (i.e., use GPGPU stuff)
So I won't be fixing this server anytime soon.
Nuke
Postby shovenose » April 24th, 2012, 5:46 pm
Shame. Well, if your current VPS provider disappoints you know where you can get a good one at a great price!
Users browsing this forum: No registered users and 4 guests
