Samxon GF caps
Re: Samxon GF caps
Postby c_hegge » June 17th, 2013, 4:26 pm
Yes. Check the PFC Transistors and switching transistors. It sounds like one of them is shorted. A shorted coil is also a possibility.
Re: Samxon GF caps
Postby Pentium » June 17th, 2013, 5:32 pm
Will do! Input coil, PFC coil, or both?
Re: Samxon GF caps
Postby c_hegge » June 17th, 2013, 5:49 pm
I meant the PFC coil
Re: Samxon GF caps
Postby Pentium » June 17th, 2013, 6:04 pm
Cool, thanks for the reply. Noob question. Never checked a PFC coil before, would I be checking resistance?
Re: Samxon GF caps
Postby c_hegge » June 17th, 2013, 6:30 pm
You can't test a coil with a DMM. It's the inductance that you would need to test. If it still blows up the PFC FETs after you can verify all of the other parts are fine, then I would try another coil.
Re: Samxon GF caps
Postby Pentium » June 19th, 2013, 11:59 am
So I pulled the first of the 3 heatsinks, the PFC diode tested good. The two power MOSFET's on the other hand, both shorted! They're FB20N50K's. http://www.mouser.com/ds/2/427/sihfb20n-107413.pdf
So I would guess that the PFC circuit is intact. I just need to find suitable replacements for those blown FET's.
Would it be a good idea to check the other silicon?
That PFC diode is an STTH8R06D
Re: Samxon GF caps
Postby c_hegge » June 19th, 2013, 1:36 pm
Those MOSFETs are the PFC Transistors. Before you replace them, check the PFC Cap and switching transistors. Samxon PFC caps aren't particularly known for problems like CapXon, but it doesn't hurt to check anyway. If it still blows up the PFC transistors, then the PFC Choke and/or another small component could be at fault.
Re: Samxon GF caps
Postby Pentium » June 19th, 2013, 2:47 pm
Cool, will do. In your opinion, is it most likely just the silicon that's bad? And would I need direct replacement parts or should I just try to match the specs? Thanks for the help. Oh and the PFC cap tested good, 306uF
Re: Samxon GF caps
Postby Pentium » June 19th, 2013, 3:49 pm
Wow, all of the switchers tested bad on the second heatsink. Is it possible that the PFC coil could kill all the silicon on the primary except for the PFC diode?
Re: Samxon GF caps
Postby c_hegge » June 19th, 2013, 7:23 pm
All 3 of them? If the 5sb one is blown as well as the main switchers, then it seems like something in the PFC circuit is responsible. A shorted coil could be an explanation. You might have a hard time finding one, though.
Also make sure no other resistors are open and no other diodes are shorted.
Users browsing this forum: No registered users and 79 guests
