Barracuda Spam Firewall 400
Postby shovenose » April 16th, 2011, 8:09 am
I got this thing to use as a server....
-Dual Core CPU
-2GB DDR2 RAM
-MSI K9MM-V / MS-7312 Motherboard
-Dual 250GB HDD
-220W PS
-1U Rackmount
The problem is that it run's Barracuda's OS.
I want to put Windows Server 2003 Enterprise on it.
But there is a BIOS password (I need to change boot order so I can boot from my USB CD drive)...
I have tried clearing bios with the jumper, removing the battery for 20mins, etc, but it still wants the stupid password.
Any ideas?
RE: Barracuda Spam Firewall 400
Postby Klinc » April 21st, 2011, 2:48 am
Hiron boot cd use one of the bios crackers
3DMARK11
Klinc
Postby shovenose » April 21st, 2011, 6:30 am
Actually, i solved the problem. I happened to have the exact same identical motherboard lying around, so i just swapoed it. Then windows server 2003 installed fine...
Postby Klinc » April 21st, 2011, 7:43 am
why didn't you just swopped the bios chips wouldn't have been faster lol [hr]
why didn't you just swopped the bios chips would have been faster lol
3DMARK11
Klinc
Postby shovenose » April 21st, 2011, 11:29 am
The only differences in the two was one had a soldered on bios and one had a different color ide and one had sounds posts and one didnt. So that was not an option ( i considered it thouh)...
Postby RWenger » April 21st, 2011, 9:02 pm
I don't know if it's exactly the same thing or not, but my high school had the Barracuda filter enabled. I hated the thing because it actually worked well, but they decided to block everything under the sun, even if it was a good thing to reference for school.
RWenger
Postby shovenose » April 21st, 2011, 9:04 pm
At my school me have "Lightspeed Systems" internet blocker. I hate that thing with a passion...every time I find a way past it, they catch it and kill my way within a week...
Postby RWenger » April 21st, 2011, 9:45 pm
Well that's their job. If you want to have a way past it, you'll have to find a more obscure hole again and again.
Of course a more permanent "solution" would be to have an administrator user/pass, but let's not get beyond simple mischievousness here. :P
RWenger
Postby Klinc » April 22nd, 2011, 8:31 am
WE HAD TYPE writers. They were electronic at least.
3DMARK11
Klinc
Postby shovenose » April 22nd, 2011, 1:52 pm
Lol.
