X capacitor measurements
Postby LongRunner » January 24th, 2022, 10:09 pm
If I counted right, I've checked 60 (to date) on the Peak LCR45 (and a few on my multimeter before that).
What I see in the data (you can draw your own conclusions):
  • As usual, the Japanese makes hold up best; Carli, LGU, uTx have mixed results; "DH" seem to be Damn Hopeless.
    While I only have one Dain sample here, reports from others suggest that using them is indeed in vain. Iskra haven't actually fared too well either…
  • I have listed climatic classes in case they correlated with reliability, but I don't see any definitive trend there :-/
  • Ceramic Y caps (while I've measured a few) aren't listed, as each piece I've measured so far is OK.
  • If I encounter anything with RIFA PME caps, they'll get their own page :group:
Suppression capacitor field measurements.ods
(24.58 KiB) Downloaded 678 times
