Power-on counter: FAIL on Fujitsu MPE3064AT
Postby LongRunner » June 6th, 2013, 9:43 pm
I just got this drive. (Fujitsu drives count runtime in seconds. Currently at 165,356,653 seconds (45,932 hours 24 minutes 13 seconds). Current normalised value of 1 (the lowest possible), threshold 20. No bad sectors. 884 write errors (this bothers me the most). In case you're wondering, 4,262 start/stop cycles.) How concerned would you be about the bearings failing??? It is very noisy - not surprisingly.
Re: Power-on counter: FAIL on Fujitsu MPE3064AT
Postby c_hegge » June 7th, 2013, 12:09 am
Depends on the type of bearings. Some older HDDs used ball bearings (a bit like fans), as opposed to Fluid Dynamic bearings. Bearing noise on those drives was very common. If it's the noise I'm thinking of (a bit like this - https://www.youtube.com/watch?v=ow3vrq3QQw0 ), it wouldn't surprise me if it was noisy like that from day 1. If it's making that noise with FDBs, then you have a problem.
Postby LongRunner » June 7th, 2013, 12:53 am
Yes, it's a ball-bearing model.
Another thing - I got an ST32140A at the same time. It makes weird seek noises even when sequentially reading some areas. Surface scan shows no problem. It's too old to have S.M.A.R.T..
Postby c_hegge » June 7th, 2013, 2:18 am
Do you mean knocking sounds when seeking? That's not a good sign. At least it's only 2GB. It's not like you can lose that much data on it :D
Postby shovenose » June 7th, 2013, 7:16 am
c_hegge wrote:Do you mean knocking sounds when seeking? That's not a good sign. At least it's only 2GB. It's not like you can lose that much data on it :D
I can't imagine back up of the drive being particularly hard - a $10 flash drive would do! :lol:
