by LongRunner » November 18th, 2013, 3:12 pm
c_hegge wrote:The bad caps were all GoldLink. I can't remember the series.
It's likely the series wasn't labelled in the first place. I've seen that myself, and my guess is the culprits are general-purpose.
Thhe fan is a Ball Bearing Power Logic...
Actually I think you'll find it has one ball bearing and a sleeve bearing, if you try to slide the impeller along its axis. That doesn't mean they're failure-prone fans, though. AVC is the only manufacturer I know of who clearly labels their 1B+S bearing fans as such.
I won't send any of mine off without first using an ESR meter (which I don't have yet) on the caps. That's because I have an MPT-301 that looked OK at first, but as soon as I plugged it in, the cap before the +5VSB ferrite coil blew.
By the way, the supervisor in the MPT-4012 is the WT7525-140. The old one had the 494/339 combo IIRC.
- Attachments
WT7525.pdf
- (421.39 KiB) Downloaded 2580 times
LongRunner on November 18th, 2013, 4:41 pm, edited 1 time in total.
