Be Quiet! Pure Power 9 CM 600 W (L9-CM-600W)
Postby LongRunner » June 8th, 2016, 4:01 am
http://www.hardwareinsights.com/l9-cm-600w-review/
Quite a mediocre unit, overall. And the capacitors used on the standby supply don't inspire confidence at all; not only are they (Cheapo) Teapos, placed very close to the diode (which will dissipate 1.5W easily at the label rating), but (according to the datasheet) a 3300μF 10V 10mm Teapo SC has a ripple current rating of 1.74A. I read before (IIRC in an article on Tom's Hardware) that the RMS ripple current through the capacitor directly following the rectifier in a flyback converter can be 80-90% of the load current; on that basis, something like Nichicon HW would be more appropriate there…
Re: Be Quiet! Pure Power 9 CM 600 W (L9-CM-600W)
Postby Behemot » June 8th, 2016, 8:11 am
That may be the reason why sometimes they put polymer just after the rectifier, followed by wet lytic after the coil.
Postby powernod » June 14th, 2016, 5:58 am
At the review conclusion you wrote:
Be aware of… /?\
Can you explain this mark a little?, i'm rather confused about its meaning :huh:
Mobo:Asrock 939a785g
cpu cooler:ArcticFreezer13 CO
GPU:Asus 750 Ti 2GB
RAM:4 GB DDR 400MHz
PSU:Seasonic Platinum 660
Tower:Coolermaster Elite 430
Oθόνη: Asus VE228HR
OS:Windows 7 64bit
powernod
Postby LongRunner » June 14th, 2016, 6:10 am
It's basically to list something that might be a problem, depending on what the user does with the unit.
Postby Behemot » June 14th, 2016, 7:04 am
Yeah mostly for remaining things which are not as bad but it is good mentioning them. Like "limited availability", "multiple revisions", "buying this unit" :group: etc.
