Today I made an EMI filtering outlet by myself (well, sort of). I found an old ATX2.03 power supply at home. An idea popped into my mind at the moment I opened it.
The power supply has two stages of EMI filtering. The stage 1 was connecting to the receptacle and the stage 2 was soldered on the main pcb. The stage1 has a little piece of PCB with 2 y capacitor, 1 x capacitor and a coil soldered on it. I was thing if I could make use of the stage 1 to DIY an EMI flitering outlet/socket.
I pulled the stage 1 out of the PSU and coupled it with an outlet. Then I connected my speaker to the EMI filtering outlet and amazing happened. The speaker used to make loud annoying sizz noise (probably coil whine), but now the noise is so low that it even isn't audible unless you stick your ears to the speakers!:clap::clap:
