Windows 8 Release
Discuss operating systems in this section. Including Linux, Mac OS, and Windows.
Re: Windows 8 Release
Postby c_hegge » October 5th, 2011, 8:06 pm
shovenose wrote:XP: It was good 9 years ago. Let's move on
That's exactly what I plan on doing...as soon as I can find a way to get FSX working on either openSUSE or ubuntu :D
Postby duckula » October 6th, 2011, 12:36 am
Browsing HWI forum in IE10
browsing HWI forum.jpg (113.18 KiB) Viewed 38442 times
Task manager
task manager.jpg (118.55 KiB) Viewed 38442 times
Windows 8 probably is designed for tablet PC with touch screen. There's no start menu in Win8 (you can enable the start menu by editing the registry though). Instead, we have a "start screen". This is what it shows if you press the win key. I'm not used to the "start screen" yet. And as far as I know, I'm not the only one who does not know where the shutdown and reset buttons are hidden. :blush: Anyway, this is just a preview version. It even isn't a beta version. The final version could be a far cry from this one.
start menu.jpg (59.95 KiB) Viewed 38442 times
Control panel
control panel.jpg (52.1 KiB) Viewed 38442 times
More settings
control panel more settings.jpg (88.59 KiB) Viewed 38442 times
My computer
my computer.jpg (75.49 KiB) Viewed 38442 times
Postby shovenose » October 6th, 2011, 4:08 pm
I downloaded it and I'm gonna burn it later and install it on a spare PC...then I'll review it!
Postby duckula » October 6th, 2011, 5:41 pm
Cool. I've already deleted it. :P
Postby c_hegge » October 6th, 2011, 6:01 pm
No start menu? 0.o I hope M$ fix that for the final release.
Postby duckula » October 6th, 2011, 6:52 pm
Seems Microsoft did that on purpose. o.O According to their offical blog, fewer and fewer people use the start menu(I don't think so though). So they think it's about time to abandon the start menu.
http://blogs.msdn.com/b/b8/archive/2011 ... -menu.aspx
Postby shovenose » October 6th, 2011, 8:14 pm
duckula wrote:Cool. I've already deleted it. :P
Why?
Postby shovenose » October 6th, 2011, 8:19 pm
duckula wrote:Seems Microsoft did that on purpose. o.O According to their offical blog, fewer and fewer people use the start menu(I don't think so though). So they think it's about time to abandon the start menu.
That's bullshit. The start menu is the one thing that makes Windows really unique from Mac OS...
Well, We'll see what happens when I install Windows 8. :lol:
Postby duckula » October 6th, 2011, 8:30 pm
Why?
Because I don't like the new "start screen". :D
Postby JLogan » October 15th, 2011, 2:55 pm
Im going to be sticking between windows 7 and linux distros for the next few years it seems.
JLogan
Return to Operating Systems
