This unit had a little bit of liquid-cooling stuff spilled on it, that's why I got it for free.
But it's been working perfectly other than the squealing.
Any ideas?
c_hegge wrote:It would be this one then (http://www.pcpower.com/power-supply/sil ... black.html). As I thought, it's one of the more standard Seasonic builds, not one of the custom built Win-tact units.
Do you have any idea which coil making the noise? If it's the yellow transformer behind the big PFC cap, then the problem is more than likely with the feedback loop, such as a small component. If it's one of the torroid coils on the secondary, then it's probably a bad cap somewhere on the secondary side.
c_hegge wrote:If you aren't going to take the PSU apart, then forget fixing it. Any diagnosis and/or repair on a PSU is going to involve taking it apart.
