mAJORD wrote:I can tell you how it has 80+ Certification... Because they have lied to Ecova! Simple![]()
Coincidently I was also looking at this supply recently, and found the same thing.
If you do a staticice search for this supply, you'll find (possibly due to a slipup from Aywun in their documentaiton to distributors), the product code " HPC-400-H14S " attached to this product
Same applies to the 650 and 750W models ( HPC-500 and 600 respectivly)
So basically, this is a rebadged 400W High Power unit. A model that's NOT 80Plus certified.
mAJORD wrote:This IMO completley throws ECOVA's new testing system into doubt. And I would not be putting any confidence into supplies that havent been tested.
mAJORD wrote:Incidently they also claim 80+ Certification for the Elite 450W. However it doesn't even have a listing at all on the 80+ site. When I emailed them about this, they told me they had just sent a unit for testing and it wasn't up yet.
This was a few months ago. and it's still not there.
mAJORD wrote:BTW these Elite's are 240V only, which I am assuming is why the input Capacitors , and primary switching FET(s) are so small, even for their lower-than-labelled rating. I would hazard a guess Aywun have requested this from Sirfa to save cost as their market is stictly 240V countries only.
