Wester547 wrote:The amount of ripple on the -12V rail is disappointing, but it is only that bad at large loads and is still very good at low loads.
Wester547 wrote:I wouldn't put trust in Korean or Chinese polymers, or even Taiwanese. I believe you said on Badcaps that most polymers aren't true solid polymers but either functional (a hybrid) or organic (conductive, meaning it still contains solvent and can fail the same way electrolytics do). That being said, only time will tell how these do, especially since even conductive polymers are a bit tougher than electrolytics (especially aqueous ones)
Wester547 wrote:it does look to me like the top honey comb grille is more limiting than the wire grille.
shovenose wrote:A bit more on-topic, but where can I purchase these?
Users browsing this forum: No registered users and 27 guests
