Why new HDDs are so unreliable
When were HDDs most reliable???
Older
2000
2001
2002
2003
2004
2005
1
33%
2006
2007
1
33%
2008
2009
Newer
1
33%
Total votes : 3
Re: Why new HDDs are so unreliable
Postby c_hegge » May 29th, 2013, 3:56 am
I never checked the AAM. I do agree though that a noisier drive is better than a failure prone one.
Postby c_hegge » May 30th, 2013, 2:04 am
You won't believe what just came my way. Another dead barra ES.2. An ST3250310NS to be exact. It doesn't get detected in the BIOS.
Postby shovenose » May 31st, 2013, 7:24 am
To think my old server was run by two 250GB Seagate ES2 disks :(
Postby LongRunner » June 8th, 2013, 5:13 am
I wonder how the new Seagate 5mm laptop HDD will fare...good thing the casing is made of steel. (But then again, it doesn't look like very thick steel.)
They've also released SSDs for laptops, and a desktop hybrid drive (with two models - a 2-platter 2TB and 1-platter 1TB; why no 3TB model???).
Also, Hitachi has squeezed three platters into the traditional 9.5mm 2.5" form, resulting in a 1.5TB 5400RPM drive.
LATE EDIT: I just found out that IBM squeezed 4 platters into 12.5mm with the Travelstar 32GH back in 2000.
Postby LongRunner » September 2nd, 2013, 6:20 am
Added a poll on when HDDs were the most reliable. The options are 200x, "older" (1980-1999) and "newer" (2010-present). Of course, I don't expect anyone to vote for the latter option.
Postby c_hegge » September 2nd, 2013, 4:07 pm
I'd say there's not much difference between around 07 and older. It's really only been the last two or three years that I've really been seeing them failed left right and center.
Postby shovenose » September 6th, 2013, 9:12 am
Just don't tell the WD RE4 and WD Blue disks used in my servers :P
Postby LongRunner » November 11th, 2013, 2:36 pm
A difficult choice, I have to admit, but I went with 2005 as by then Western Digital (the last manufacturer to do so) had made the switch to fluid-dynamic bearings.
