With this hold-up time being so short, not even a UPS (neither a cheap/off-line model, nor an older one with worn out relays) may help you under full load, as its own transfer time may be longer than this.
. So, even though the OPP isn't present, the OCP is working, right?Single set of 12V design will result OCP protection will be very close to the OPP (Over power protection)
So the design is using the OPP protection!!
Of course you can just buy a much higher-rated model, like the CX750M. But why do that? Why not just get a higher-end series with lower power for at a similar price point?
