LongRunner's Mini-review Collection
Hager WBP4S, WBP2S outlets and WBSV1 switch
Postby LongRunner » October 7th, 2023, 1:56 am
I've meant to examine these for a while, since my mixed outcomes with Connected Switchgear (CSG) products last year.
On September 27 in Rexel, I didn't end up buying what I came for but found them below Hager's protection devices.
An overview of Australia's electrical accessories is in order: Our leading brand is Clipsal (owned by Schneider Electric since 2004, after which the Gerards got back in the business with their Trader brand; some electricians swear by them but I'm not so convinced), with HPM (owned by Legrand since 2007) playing second-fiddle. In the 1970s Clipsal and HPM each had a “Standard” range (both still available to some extent, but often at inflated prices) requiring fiddly plastic caps over the mounting screws (since they normally screw into an unearthed metal bracket, which could be made live by a loose wire); in the '80s HPM introduced their Excel range with removable cover plates, but its glory lasted only a few years prior to Clipsal's much-superior 2000 Series (which remains Australia's most-popular switch/socket lineup today) using a common border surround, with multi-gang surrounds available to neatly mount up to four plates side‑by‑side (or three end‑to‑end). Along the way came Clipsal Classic (C2000; a direct competitor to HPM Excel, with similar dedicated cover plates), Clipsal Slimline/Eclipse (SC2000/SL2000; thinner Classic variants, Eclipse with rounder corners) and HPM Linea (likewise), Clipsal Prestige (P2000) and HPM COMO (with large switches for aged‑care facilities) among others. Ring-Grip also had a fair run, but died out 20-odd years ago (now their name is just slapped onto cheapo appliances).
Now there's also the Clipsal/PDL Iconic (3000) series with user-swappable rockers, but it's not as well-made as the 2000 Series so I remain unpersuaded.
HPM/Legrand's Excel Life range is somewhat improved over the original Excel, but not quite enough to win me over either.
So observing my underwhelming general track record with late Australian products, can German giant Hager do better? Let's find out…
WBP4S quad outlet
C2015D4 versus WBP4S.JPG (201.61 KiB) Viewed 99533 times
One of the first Hager accessories in the local Rexel (AU$53.20), and a welcome substitute for Clipsal's C2015D4 (my unit having a very yellowed cover).
Being designed to retrofit in place of a double outlet (largely for convenience but also helpful in heritage-listed houses like the one I'm now living in, where you need to minimize any irreversible alterations), their profile is raised to accommodate the outer sockets over the wall surface. It of course has its own longer surround (thankfully also polycarbonate), with additional columns covering the standard (84mm) mounting points. Just be aware that it's slightly wider (211mm) than the Clipsal (196mm) and the optional corner fixings are further-out accordingly, so check the space before you rush out to replace your old C2015D4…
End screw storage.JPG (183.27 KiB) Viewed 99533 times
However it also has wider socket spacings (53mm between the inner sockets and 46.5mm from outer to inner, where Clipsal has the basic 45mm intervals), and built-in screw storage (rather than the C2015D4's provided screw bag).
Quad outlet backs.JPG (641.84 KiB) Viewed 99533 times
Hager have chosen a distinctive translucent blue (or “blu”) for the rear frame; while the iMac was 25 years ago, this does reveal that the switches are double‑pole as in the Clipsal, Trader and Deta models (perhaps because the quad-outlet layout doesn't make single‑pole switching much easier anyway).
So to apply Hager's model-numbering scheme consistently, it should really be called the WBP4DS. Like the C2015D4, no part protrudes from the back.
The circular recessed area is where an extra switch goes in the WBP4XS; this pushed the terminals quite low, and indeed the inner sockets had to be spaced-out to accommodate them. Unlike Clipsal, Hager opted to keep the terminals symmetrical (as befitting the overall layout).
I'd fix the white balance if aesthetics mattered here; you can still see what's there.
Screw gap.JPG (191.57 KiB) Viewed 99533 times
The screw heads do bottom-out on the terminals before their tips reach the bore, but will still grip a single 2.5mm² core solidly (provided it's twisted well) so this isn't a crippling flaw (but do verify the grip if connecting already-flattened ends, or if you do have smaller wires in some location).
The thread appears to be M4.5×0.75, in 6mm bores.
Inside front.JPG (511.53 KiB) Viewed 99533 times
As usual in Australian outlets, the shutters are opened by the neutral pin so only protect the active.
Thankfully they are closed by proper springs, not the unsatisfying plastic-leaf arrangements in Clipsal/PDL Iconic (and many older Kambrook power-boards).
WBP4S inside, Clipsal 30M rocker for comparison.JPG (308.91 KiB) Viewed 99533 times
The red dot is an insert rather than surface marking (an approach common on UK sockets, but previously unseen here in Australia), so can never wear off; although I wonder if it affects the physical integrity (Clipsal rockers are thicker but still often cracked where the dot was stamped deep enough to create a weak point).
At least Hager have thickened the rocker plastic immediately around the insert. Stationary contacts are 2.6mm diameter (5.3mm²), moving contacts 3.1mm diameter to tolerate some misalignment. The barrier between switch poles could be taller (like in Omron's A8L appliance switch), but is no worse than Clipsal's. The incoming active and neutral busbars are 0.7mm brass, 4.6mm wide at the narrowest point (but 5.7mm across the top part); calculating to 0.9–1.1mm² Cu equivalent, which may seem low for up to 20A combined but should suffice (the CSG BS-POD10 survived with less than half the Cu equivalent).
Socket contact comparison.JPG (235.1 KiB) Viewed 99533 times
Socket contacts are all 0.7mm phosphor-bronze in full-wiper formation (where the C2015D4's active and neutral are a half-wiper, half-scraper hybrid which might scratch away at plated pins).
It handled 2×11A fine and survived an overload to 2×16A (at least for the 10 minutes I tested) on top of that.
WBSV1 switch (WBSP1 plate + WBM16AX mechanism)
The other item available at Rexel (AU$8.44), although Hager's ranges go up to full 6-switch plates. From the front it looks unremarkable, so let's see the back:
WBSV1 back.JPG (209.56 KiB) Viewed 99533 times
Hager's switch mechanism(s) are mounted by their nifty (and patented) Roto-loc system, which you can lock/release with either a dedicated tool (WBMS, as shown in the catalog) or 5.5×1.0mm bladed screwdriver in the provided slot; preventing push-back by vandals, without the fiddly screws traditionally added for that purpose.
As standard in Australian switches, they can be mounted vertically or horizontally in the same plate.
Angled view.JPG (128.94 KiB) Viewed 99533 times
Otherwise the mechanism is straightforward; SPDT (with a breakaway “T” barrier over the second way) rated for 16AX, plus looping terminal on the left.
Some other mechanisms have different body colors (orange 20A, green double-pole, red intermediate).
WBM16AX open.JPG (96.8 KiB) Viewed 99533 times
The rocker has a two-layer construction (some black plastic behind the white polycarbonate) presumably to provide the stated chemical-resistant pivots and arc shield; the outlets have simple one-layer rockers.
WBP2S dual outlet
WBP2S left, WBP4S right
Rocker comparison.JPG (165.27 KiB) Viewed 99533 times
This was ordered online among three Clipsal items. The rocker shape is a bit different (two adjoining flats instead of the concave curve) for whatever reason.
WBP2S back.JPG (300.81 KiB) Viewed 99533 times
The two sockets have 48mm between centers.
While riveted together (so I can't disassemble it without damage), the blue tint is light enough that I can see the active and earth contacts are brass here (only the neutral remaining phosphor‑bronze); so not quite as robust as the 4-outlet model, but still on par with recent Clipsal 2025 production (which has brass A/N, phosphor‑bronze E and is clipped together) – and the WBP2S doesn't use the solid neutral terminal as half of a socket contact, if that helps.
Shutters seem to be the same design (I can locate their springs with my magnet stack), although a bit rougher to open initially (these can take a bit of a break-in).
I decided to test the switch breaking capacity; over 10 cycles at 4800W (240V 20A) and still working (though with some black deposits on the contacts).
(IEC standard tests also use 1.1× the rated voltage, but I'll cross that bridge when I have the equipment…)
All three of these items are manufactured in China, but they aren't used in Germany so it's not like there'd be too much point making them there :P
Terminal screws are all plated steel, but this is already the case through most of the competition (aside from Clipsal 30M switch mechanisms).
Though I do wonder if Hager's mounting screws (nickel plated?) might be more prone to rusting than the usual zinc-plated screws…
Update: If you have the leftover mounting screws from a Clipsal 2025XA (which for whatever reason are longer than usual), those are zinc-plated and the correct length to substitute in the WBP4S. However Hager's regular-size plates have narrower screw channels which won't quite accept the Clipsal (or Connected Switchgear) screw head diameter, except for those from the newer Clipsal/PDL Iconic series.
Conclusion
Hager's Premiere switches and sockets are very solid competitors to Clipsal 2000 Series (and HPM/Legrand Excel Life for that matter, nevermind the original Excel), and the WBP4S in particular makes Clipsal's C2015D4 “Awesome Foursome” look positively lackluster in comparison.
You can, of course, stay with Clipsal 2000 Series switches and single/double outlets if you value Australian manufacturing higher than Hager's technical advantages. For me it's a close-run thing; for switches decided mainly by already having several Clipsal mechanisms and plates, and the single/double outlets are even harder to choose between – Australian made or shuttered? (Yes, the Clipsal 2025S exists; but at an exorbitant extra cost, compared to the base model or Hager WBP2S.)
Also bear in mind the mounting screw head diameters, as noted in the update above; definitely use Hager's mounting blocks with Hager accessories.
But the C2015D4 has long since been made in China (and now Vietnam) anyway, as are most of Clipsal's more-exotic items.
So as long as the WBP4S's wider form is OK, it's the clear winner. In the (hopefully few) edge cases where the WBP4S doesn't fit, you could fall back on Trader's PUBIG4 (which looks suspiciously similar to the cheapo Deta/Arlec, but hopefully with better quality control) as a second-choice C2015D4 replacement.
I'll install the WBP4S in my kitchen, upgrading from the CSG BS-POD10 there (and changing another on the same wall to the WBP2S for consistency)…
Reason: Added link to the Moans; non-breaking hyphen
Micro-reviews, round 26
Postby LongRunner » November 20th, 2023, 11:48 pm
“EL01084” power-board: A half-decent shuttered unit, although it has some shortcomings (the back bulges downward making the rubber feet ineffective, and the circuit breaker is the same type as in the C6PB so can be defeated by holding the button). Unlike most of our power-points, the shutters are of the type requiring active and neutral pins to be inserted simultaneously to open. Each push-button switch (double-pole as seems to be standard in power-boards) contains a white LED (two antiparallel diodes I think, with a 680kΩ resistor). The plug pin insulation is a bit rough, and cord is slightly short (96cm) of the stated 1m, but flexible enough. Jackson are selling this as the latest version of their PT1614; you may also find it under other brands.
If you don't need shutters or switches I'd probably stick with the Kaifengs, but at least the option is there…
There's also a black 6-outlet model but if its surge suppressor is like in other Jackson power-boards (with no failsafe), then I'd look elsewhere.
Micro-reviews, round 27
Postby LongRunner » November 28th, 2023, 11:17 pm
Trent & Steele TS 611 kettle: I grabbed it for AU$6.50 at the second-hand shop today (among various small items, mainly audio cables of types I don't already have in abundance; and a few older B22 holders with nice metal bayonets, should I need them for a repair) to go in my unit kitchen. (I first found a Ronson kettle, but left that one behind as it's the first kettle I've seen with a fixed cord :silly: and its element is quite scaly too; anyway it was missing a price sticker.)
It was in pretty good condition, just needed basic cleaning (and the plug pins were tarnished even though nickel-plated, so I wire-brushed them).
Internally it uses a Sunlight SLD-128 control, which actually has a significant advantage over the popular Strix type: The Strix mechanism switches both poles, and has a bimetal cut-out on each side (which switches it off if overheated) but you can defeat these by jamming the switch to commit arson.
The Sunlight SLD-128, on the other hand, switches only the active in normal operation; one of the two bimetal cut-outs pushes the main switch off, the second cuts the neutral off independently (so if you hold the switch down, it can still prevent fire).
(On my test the neutral cut-out responded first, but it doesn't really matter as the element retains enough heat to trip both cut-outs anyway.)
The base also has a shutter over the active and neutral contacts (which the Strix design lacks).
Unfortunately I can't find it on T&S's current site (or what passes for one) but if you find one at a similarly reasonable price, go for it.
(Even the K-Mart horrors sell new for AU$7.50 or thereabouts.) Seems relatively quiet for a flat-element kettle too.
Its only obvious shortcoming is that the element is 2200W (not the full 2400W) and has no obvious silicone sealant at the ends.
Micro-reviews, round 28
Postby LongRunner » January 30th, 2024, 5:13 pm
StarTech S3510SMU33 3.5″ USB 3.0 to SATA III HDD Enclosure with UASP Support:
Having to replace my crappy Jaycar “NexTech” enclosure (with a broken tray), I wandered online, quickly gave up on the “reviews” (as even technology reviewers have lost the plot nowadays :() and fell back on common-sense, picking this one; it's relatively expensive but between that, the aluminium shell and ASMedia ASM1153 bridge chip (rather than the buggy JMicron perils) it seemed as safe a bet as any. (I'll worry about the lack of automatic spin-down when one of my HDDs fails younger than 43,830 hours; so far only the known duds – namely post-7200.11 Seagates – have done so without being seriously abused.)
It includes a Ktec KSASB0241200200D5 +12V 2A plug-pack SMPS, supporting each common plug type (AS/NZS 3112, BS 1363, CEE 7/16 and NEMA 1-15).
The mounting screws are good quality with zinc plating (unlike most PC screws), although the tray is secured in the shell with M3 screws so don't mix them up…
The tray is still plastic (I'd prefer aluminium), so time for a temperature test; my two hottest-running SATA HDDs are the WD3003FZEX-00Z4SA0 (5 platters at 7200rpm) and ST380013AS (only 1 platter, but high +5V draw during access – due to its use of linear regulators for the SDRAM and Vcore supplies, as was usual at the time – and hence will also be a good test of the enclosure's +5V buck converter :mrgreen:).
(The NCQ-capable Barracuda 7200.7s from late 2004 switched to buck converters and became considerably more power-efficient; 7200.8 and later used buck converters on both PATA and SATA models.) The bright blue LED (3mm in a light-guide) belongs in 2004 for sure, but I can always change it out…
Update 2024-02-04: I indeed changed to a diffused yellow-green LED, and replaced the three 100μF 16V Stone electrolytic caps with Rubycon YXJ.
So I got my thermometer out, fed the T1 thermocouple through the front vents and around the side of the drive to the back, and taped it down (I of course have polyimide tape for sticking to heating appliances, but normal cellulose tape is fine at HDD temperatures) with thermal paste between the thermocouple bead and HDA; the T2 (ambient) thermocouple taped off to the side (in the air). Ergo, I win at reviewing it already :lol: As the worst-case scenario I tested it horizontally (on top of a Sistema lid to thermally insulate it from my PC case); while vertical operation is preferable if you're keeping the drive permanently in a safe location, since I mainly use this for my back-up drive that'd just be unnecessarily precarious. My ST380013AS reached 20K above ambient after a read benchmark; borderline (since ambient temperatures can approach 40°C in Australian summers if you don't have air conditioning), but still more-or-less survivable.
I may try the WD3003FZEX-00Z4SA0 later, not that I expect a much-worse result as non-NCQ 7200.7s dissipate more power while reading (11W for the ST3160023AS, perhaps 1W less for the ST380013AS) than even 4- or 5-platter modern drives do at idle; 11W is as much as the infamously hot-running ST39140A idled at (good job the Barracuda 7200.7s had mature FDBs which could survive the heat better, though the STMicroelectronics MCUs often couldn't :silly:).
(I guess I should just be grateful that nobody's still dumb enough to use a linear +5V regulator in the enclosure; running my old ST380011A – thankfully with an Agere MCU and TI SH6950 motor driver – in such an enclosure ended up linearly regulating +12V all the way down to the +1.5V core; that was some “efficiency” and it's no wonder the temperature fluctuated so wildly :rolleyes:; and I think the regulator itself ultimately died from severe thermal stress…)
Last edited by LongRunner on February 4th, 2024, 11:18 pm, edited 1 time in total.
Reason: Platter count correction (opened my most-used, completely-knackered WD3003FZEX)
Micro-reviews, round 29
Postby LongRunner » February 10th, 2024, 7:16 pm
Kambrook KRH100: From a garage sale, I finally got one of Kambrook's tumble-proof radiators :mrgreen: it's not the original model (that was 1200W with both bars on, where this one is just 1000W) but it does indeed recover to upright after tipping it forward (not so much when tipped backward, but then it's radiating up which isn't the end of the world). Unlike the Goldair GSIR220/RH0002, the two bars have separate rocker switches so you can alternate and even-out their usage (not that the previous owner bothered, observing how worn the top-bar switch's markings are :silly:); and this model has an all-metal casing (except the carrying handle, and of course switches), unlike the Goldair's mostly-plastic construction with only critical parts (grille, reflector and the convected-heat shield behind it) being metal.
That said, the GSIR220's forward-facing radiation pattern is probably better for use as a true personal heater, whereas the KRH100's is more-diffused vertically.
Kambrook were also rather brave to use a PVC cord (where the GSIR220 has rubber); though an off-cut I tried (from a damaged extension cord) survived (albeit barely, with slight impressions) contact with both radiators, so it's not on the level of those cheapo soldering irons with PVC cords (that's reckless :eek:).
I guess the eventual mandate for tip-over switches (which the KRH100 didn't have) rather diminished the tumble-proof design's appeal…
(In any case Kambrook pulled out of radiators altogether a few years ago, having become probably too-small of a niche to be profitable.)
Micro-reviews, round 30
Postby LongRunner » August 19th, 2024, 1:25 am
Before I move onto building my own site, here's a big round-up to go out with:
DēLonghi DEFL605G:
Given my disappointing experiences with late Australian appliances (due to inadequate quality checking of imported components, and often rather rudimentary functionality) I decided to quit while I'm ahead, purchasing this Italian-made cooker (a few hundred dollars more than our local “Chef” brand, but with more oven modes to justify it) late last year instead. This is the dual-fuel model (gas cooktop/electric oven), whereas the DEFL605E is all‑electric with glass‑ceramic plates. As obtained it's configured for natural gas, but includes the conversion kit for LPG; however for town gas (as we have in parts of Albany) you may need further conversions.
Although officially meant to be hardwired, since it only draws 2070W total at 230V it can be fitted with a normal 10A plug.
(Of course cookers are required to have an isolation switch nearby, but the power-point here is in plain sight so that's good enough for me :mrgreen:)
Before it arrived I purchased 1m of 3×1.5mm² V‑90/5V‑90 cord (the manual says “V‑105” but that grade was long since renamed to V‑90HT, it's much harder to obtain and given that you're not supposed to run the cord where it can exceed 50K above ambient, I figured V‑90 is fine), although I got a bit ahead of myself as it does come with a cord attached (nominally H05RR‑F3G1.5 but with 90°C EPR insulation and sheathing so it's really closer to H05BB‑F, here's the specification); but having already wired the plug onto my PVC flex (and overload‑tested it to 20A :cool:) I went ahead and wired it in (I did need to crop my ferrule on the neutral core to fit in, but still easy enough), keeping the original cord intact in case we later resell the cooker…
For some reason DēLonghi's designers felt the need to use fancy pictures for the “leavening” (top element without fan) and “bread/pasta” (both elements with fan) oven modes, instead of straightforward diagrammatic icons as for the others :s; but otherwise operation is as normal (notwithstanding a slight “phantom” glow from the neon indicator, when the thermostat is off in the light‑only or defrost mode).
The legs allow you to clean the floor beneath, in a way you can't do with many others (like my previous Chef model); I vaguely hoped that the gas controls would also be smoother, but they seem similar in having a wide span of effectively‑full gas (they do go lower, which can be useful for sensitive foods but which you should also be careful with – especially on the three single‑ring burners, the flames are barely visible on minimum gas). There's also a drawer below the oven, which is handy for storing the wok stand (I have yet to use a wok for anything) and other accessories not currently in use.
Anyway the hob burners perform as well as, or better than, any others I've used to date…
Oven temperatures measure reasonably accurate (the maximum goes noticeably higher than the marked 250°C, but otherwise it's within a few °C).
The normal oven elements, being relatively low-powered (230V 800W top and 1000W bottom), only barely glow (the 230V 2000W grill element glows brightly, by necessity, but I haven't really used the grill anyway) even without the fan, so should last a good while (though somewhat slow to heat up).
It seems well-insulated too (the side panels – and top when not using the burners – stay cool to the touch; the door gets moderately hot but not too bad).
So far my only (minor) complaint about build quality is that the controls are mounted with zinc-plated screws to a stainless-steel panel (to be fair, only the top is austenitic anyway – the rest is ferritic – but that's still a significant step above the all‑ferritic Chef and Westinghouse models), although at least the two fully exposed screws (on the side edges of the top) and those mounting the top to the burners are austenitic. It doesn't have a splash guard at the back, but maybe the Italians learn to cook more cleanly :lol: The knobs do have spring-loaded collars to minimize ingress into the control mechanisms, though.
However if it's any consolation for Australian manufacturing, I arranged to install this cooker after replacing the busted fake floorboards (in both my unit kitchen and bedroom) with tiles, and for that job I picked out Australian‑made NCIA Kierrastone tiles (available locally at Brocks) :-).
SABA SA-PM9020 popcorn popper: Yes, we're dealing with another zombie brand; but in construction it actually looks more robust than the Sunbeam popper (I think it was the CP4500, superseded by the more-rectangular CP4600 then discontinued altogether) we had 20 years ago, as the SA‑PM9020 has a solid phenolic chute (rather than the CP4500's thin phenolic layer over melty polypropylene) and lacks the CP4500's lid interlock (which broke mechanically), but earns some safety points back with an additional thermal cut-out on the popping chamber wall (180°C). The element does glow a brighter orange (than the CP4500's dull red) so would oxidize and eventually burn out if run long enough, but if you were using such an appliance commercially you'd want one with a brushless fan anyway :mrgreen: as for household use, even if used once every day (given the maximum specified 5 minutes per operation) you'll only clock up (at most) 30.5 hours per year (or 761 hours if it lasts 25 years, which both the element and carbon‑brush motor should survive). Running for longer than allowed will trip the thermal cut‑out (as the air inside reaches 200°C easily). Perhaps surprisingly, the element (1000W) is genuinely for 240V (rather than over‑running a 230V one); beneath it are the normal bimetal cut‑out (150°C?) and thermal fuse (229°C). One end wasn't tucked properly and was touching the insulation on the fan tap‑off wire (at least that has a fiberglass braid over the silicone), and the across‑motor capacitor is an electrolytic (Chenxing 1μF 50V) so I replaced it with an X7R ceramic (at least the terminal‑to‑body capacitors are ceramic, 100nF); but both flaws are easy enough to fix (once the cord grip is removed and switch connections unplugged, as the bottom isn't separable). I'll grant that Sunbeam included more RFI filtering (with inductors and a 47nF X2 capacitor), but this model doesn't emit too much anyway (my AM radio was well within 1m to detect it, even with the original electrolytic cap).
Some pieces of popcorn get expelled too energetically (and especially early on, they may take unpopped kernels with them), but I suppose all such hot‑air poppers have this problem to some extent; otherwise it comes out fine, and poses far less risk of burning the corn than microwaving does. So for AU$20 (while stocks lasted) at Coles, I can hardly complain…
Thomson Scenium TM-AF1056 12L air fryer: And another (I believe), again on clearance (AU$80) at Coles.
I don't like the all-blue LED display, and there's an odd delay between opening/closing the door and light on/off, but it works well enough.
The internals look more solid than I expected (both PCBs are FR-4 even though single-sided, and the heater relay is rated 17A 250V), so maybe some of these rebranders have some idea what they're rebranding after all? Internal air temperature is sluggish to rise, but seems to eventually get at least near what's set.
I don't recommend opening it, though, as the top cover is clipped-on with no discernible way to release them, so 3 out of the 7 clips broke.
Just a quick side rant: Using the Greek Xi (Ξ) as E (as they've done in SCΞNIUM) is a tired, annoying cliché. :rolleyes:
Vulcan 7375LG: Only slightly newer (June 1993 on the cord) than the 7343 I found 4 years ago, but thankfully much improved safety-wise:
This model actually does have a thermal cut‑out (Klixon 1NT08 L90-MR) mounted near the thermostat (the modern oil‑filled heaters have two cut‑outs on the heater fin near the elements, but at least it's something), the sharp‑edged cord‑chafing storage compartment has been ditched, and instead of a terminal block with questionably‑prepared wire ends (soldered on the very tips to keep the strands together) the cord wires have normal crimped‑on blade receptacles.
I'm not such a fan of the thermostat mounting (clipped‑in and rather wobbly) but that's no big deal…
This is the full 2400W, 16-fin (versus 11 or 12 fins on current 2400W models) model with a rather nifty timer, which even has clock hands :clap:.
Unlike the 7343 it has 3 power settings (1000+1400W), not sure if this divided the 2000W and 2400W models or was one of the 737* series' improvements.
I'm unsure why the original owner left it outside, but the neutral pin was bent so maybe they just weren't strong enough to straighten uninsulated pins :P
“Quantum” aluminium torch (article no. 439127): Apparently equivalent to the Energizer LCM2A5 (now dead), but seems better-made despite selling cheaper (AU$12 only in Woolworths, but you can probably find it under other brands elsewhere), and can be stood up (the Energizer can't as its power button sticks out of the tailcap). Just be careful when changing batteries, as the O-ring pings off very easily.
Atom AT3014 series LED oyster lights: They seem equally as solid as their downlights (perhaps a bit better, since at least the 12W AT3014 models don't have Dain X2 capacitors to degrade), and again dim smoothly with the Clipsal 32ELEDM2.
Equip LW601 20cm marble frypan: Not perfect (the handle mounting bracket is zinc-plated steel even though the screw is stainless, and galvanic corrosion occurs between the aluminium pan and steel induction plate whenever washed), but it works.
Crest CCPB4 (Approval no. GMA-515446-EA): Close to the Kaifeng KF‑MSD‑4A, but not close enough :-/ the indented regions on the socket contacts (meant to increase their grip force) here extend up to the actual contact area, making plug insertion/removal much rougher than in the real thing.
For AU$7.50 (at Coles) I can't complain too hard, but just know what you're getting.
DēLonghi HCX3220FTS: As if I needed any more heaters :rofl: but I found it second-hand for AU$10 so worth checking out.
(A brown pencil was hiding inside it, so I'm glad I got that out :omg:) It includes DēLonghi's “Hi-Fi” arrangement with blowers at both ends (instead of just one as in the HSX3324FTS and other convector/fan heaters); you're probably better off just using a fan heater (like the HVS3032 or a cheaper or more readily-available alternative) than going to that length, but I suppose it satisfies the people convinced that fan heaters are “useless” :group:
Although it seems as solid as the HSX3324FTS, its excessive retail price (AU$359) forfeits any awards, considering that it still contains ordinary zig‑zag elements and is less powerful. (AU$250-ish would be quite enough, relative to the HSX3324FTS's AU$169.)
If you're prepared to spend that much, then consider a PTC convector like the HX65L22 or HX65L15…
Oddly, the neon indicator only lights with the fans (the HSX's lights on all settings, like most other heaters).
Micro-reviews, round 31
Postby LongRunner » January 21st, 2025, 10:16 am
I've been somewhat forced to go back on my plan that round 30 was the last, as affairs at home eventually got as rough as the DiamondCrash Minus 9/10/11's landing zones :( like Maxtor, we've hit rock‑bottom; but unlike Maxtor I haven't completely obliterated my reputation in the process, so it's only up now :sleepy:
SABA SA-SE306 handheld steam cleaner: Another surprisingly-solid budget appliance from the company, with every likelihood of outlasting both big unsatisfying models we had before – the dangerously-defective and made-to-break Euroflex (Eurofux?), and the disappointing Kärcher SC3 which uselessly tried to “reinforce” its steam hose with woven cotton :silly:. The short internal hoses aren't reinforced, but I take that they work within the elastomer's own limit.
Exascend EXSAM1A240GV125CCE: With proper enterprise-grade SSDs now down to reasonable prices (<AU$1/GB at Mouser), I've gladly replaced (and condemned) the leftover 120GB Kingston A400 I used before (on its last legs almost-exactly 3 years after installation, which fits the 3-year warranty :P), bringing my PC back up to lightning-speed :clap: I can understand the attraction of large, cheap SSDs for game installation – but to do so safely I would advise a 3‑tier storage arrangement: A modest enterprise SSD for the OS, your small files and productivity applications; a large consumer SSD for the game installations; and an (even larger) enterprise HDD for the installers, audio/video and other bulky data.
Obviously on a newer mainboard I'd use the related PE3 series (M.2 and NVMe 1.2), but this is more than satisfactory for my tasks at home.
Mind you, its SATA header still doesn't have nearly the gold-plating thickness present on the Barracuda 7200.7 (at least NCQ models) or 7200.8; and now that the HDD reliability reckonings have largely-concluded (with Seagate forced to upgrade even Grenada to be half-decent under new model numbers, much as Apple and other furious OEMs forced Maxtor to fix the start/stop cycle rating in later DiamondMax 10 and the last few DM+9 batches), I'm willing to try the ST10000VE001
(The SSD reliability reckoning is only just starting, so I hope; and with even Crucial consumer models finally fallen, maybe HDDs will see a renaissance too.)
Last edited by LongRunner on February 8th, 2025, 7:25 pm, edited 2 times in total.
Reason: Changed my HDD choice from ST8000DX001 (4 disks/8 heads) to ST10000VE001 (the full 5 disks/10 heads in air)
Micro-reviews, round 32
Postby LongRunner » January 25th, 2025, 4:43 pm
Kambrook KRC300: Great things really can come in small packages; with this small rice cooker (1.5 cup nominal), Kambrook used its niche position as an opportunity to build it to a higher standard than any of the bigger models I've seen – it even has thick fiberglass insulation between the inner and outer walls (only standard in Japan AFAIK, where rice cookers originated – of course here, the Japanese brands only sell their “fancy” and gimmicky models).
The pot is also much better‑coated (on both inside and outside) than any other model I've seen (from any brand), and it cooks rice as well as any I've used.
Earlier production (including one I saw on display in RetraVision) did have off-spec pins in the C14 inlet, but that's been corrected by now :thumbsup:
(My unit is dated week 02 of 2024, so any produced on or after that date should be fine; earlier dates you'll need to check yourself.)
For those affected, the Qualtek 703W-00/03 (rebranded Solteam?) should replace it perfectly (here at Mouser).
The included C13 cordset is 71cm long, made by Anjia with phosphor-bronze socket contacts, pin dimensions verified correct and passes 10A loading.
So it's the closest thing you'll easily find to the classic Japanese models of the early 1980s, and my AU$60 was well-spent :clap:
The only thing stopping it short of Gold is that the keep-warm heater (240V 25W in series with the 230V 200W cook element) overlaps one of the cook element's mounting screws; and the silicone sealing around the element ends isn't quite as clean as in the BKE200, but still acceptable.
One of the microswitch's blade receptacles is a tad loose too, but at <1A this isn't the major concern it would be in a room heater or a kettle…
Micro-reviews, round 33
Postby LongRunner » February 4th, 2025, 1:11 am
Simplecom SE328 USB 3.0 to 3.5″ SATA HDD enclosures: Well, they're crap; did you expect anything better for AU$29?
Their aluminium casing is their only good feature (besides containing 2.5″ mounting holes if needed); and they have the buggy JMicron bridges.
Being bought new, it's tragically ironic that they work OK with my >20‑year‑old ST380013AS, but don't seem to cooperate with the ST10000VE001 :rapidfire:
But they were all Umart had (now that Aus PC Market has fallen :(), and the monetary loss wasn't too much (and at least I can keep the +12V 2A PSUs).
Keychron C2-M3Z Mechanical Keyboard: This, on the other hand (now that my old Das Keyboard is malfunctioning and has worn keycaps anyway), actually seems to work well (despite not using genuine Cherry MX switches) and feels great to type on, so was probably worth the AU$99…
Users browsing this forum: No registered users and 33 guests
