Rock PS-RK500 Review
Postby shovenose » May 30th, 2011, 8:48 pm
Re: Rock PS-RK500 Review
Postby LongRunner » May 29th, 2013, 5:00 am
Actually, the label only rates the unit for 29A total on the 12V, so the original 12V rectifiers are enough...barely.
But yes, it falls way short of being good for the 5V rating.
Postby c_hegge » May 29th, 2013, 3:09 pm
You are right. I didn't notice the combined maximum there. I have fixed the review
Postby LongRunner » May 29th, 2013, 5:32 pm
You don't seem to have done a very good job of fixing it.
248W
Should be 348W
Again, this is not enough when the 5v rail is rated at 28A.
Remove "again" (as it no longer makes sense after the edit)
While not undersized like the other rails, it is just enough.
Make that "the 5V rail" (again due to the edit)
Also, the link to the review from here is broken.
Postby c_hegge » May 29th, 2013, 6:44 pm
Done
Postby shovenose » May 31st, 2013, 7:27 am
Some of the old reviews have borked links since we switched from MyBB to phpBB... I actually liked MyBB better but I knew how to make a good phpBB skin and not a MyBB skin :D
Postby Wester547 » May 31st, 2013, 2:12 pm
FSP overrating their PSUs, and on a 230V input!?? Shame on you, FSP! And a 20A rectifier when a 28A output is touted... I know it's a full-wave rectified output and that it has an 120mm fan but even then... 20 gauge wires and 680uF input capacitors are disappointing, too... what is the bridge rectifier rated at?
...Oh well. It's a half bridge topology, guess I shouldn't be surprised. Shoulda overspec'd more and gone with double forward, and APFC too... but maybe they just rated it at a lower temperature than 40*C/230V...
Postby c_hegge » May 31st, 2013, 2:22 pm
I don't think it's so much FSP overeating them. I think Rock just took a 400W FSP product and stuck a 500W label on it. I can't remember what the rectifier was rated at. I haven't seen one of these units since I originally published the review.
Postby LongRunner » August 11th, 2014, 3:53 am
The capacitors on the secondary are a bit of a let down too, since all of them are made by Teapo.
There's also a CapXon near the +5VSB transformer.
Postby LongRunner » August 17th, 2014, 6:37 am
I don't see any sign of an inrush limiter. There's just a wire jumper where it should be. If that is indeed the case, the inrush current could exceed 200A — very high indeed. Unless it's installed somewhere else, but I can't see where.
Users browsing this forum: No registered users and 76 guests
